Efficient way to monitor Quartz Jobs using AppMon
saurabh_chakote
Newcomer
Is there any efficient way to analyse Quartz Job in AppMon? I've created a sensor for "org.quartz.Job" but its not efficient.
asad_ali
Advisor
Saurabh
The best way to do it is to do CPU sampling. Using the CPU sampling, you can easily find methods that could be marked as entry points in DT.
vsingh1
Newcomer
@Asad A.It is not very clear when you say entry points. There are no entry points for quarts. It runs behind the scenes and it we would like an alert when for some reasons quartz job is throwing exception or stuck for any reasons.
