Enable UEM for Auto-detected applications
rravindran
Inactive
Do I need to manually enable UEM for the applications those were automatically detected based on hostname ? Or it will be covered default under "Default Application" ?
Babar_Qayyum
DynaMight Leader
DynaMight Leader
Hello Rejith,
You can configure UEM settings to apply to all applications using Default Application tab, or configure settings in an application-specific tab by adding a specific application, which creates a seperate tab for the application.
The agent location path used when injecting the JavaScript Agent into your HTML code and sometimes '/' would be restricted, therefore, you will have to ask for the exact documentation location, for instance, /myapp/ in agent location to instrument the JavaScript.
Babar
