Generic Execution Plugin - Remote Execution
gpetrouis
Newcomer
Does the "Hosts" parameter in the Generic Execution plugin do anything or is the plusin always executed within the context of the collector?
Basically I want to know if I can use it to execute commands remotely or is that only for SSH hosts?
thanks
George
ynias_reynders2
Contributor
You can use a Invoke-Command or Enter-PSSession for Windows hosts. But yeah, the "hosts" tab is pretty useless
