Generic Execution plugin Encountered Error When I using SSH
ymaaa
Organizer
I'm using Generic Execution Plugin to execute a remote script on a linux server. I got the following error.
SEVERE [GenericExecutor@com.dynatrace.diagnostics.plugin.extendedexecutor.GenericExecutionPlugin.action] setup method: password authentication method not supported by server '<LXV****>'
2018-06-01 23:27:32 FINER [GenericExecutor@com.dynatrace.diagnostics.plugin.extendedexecutor.GenericExecutionPlugin.action] Entering getExceptionAsString method
2018-06-01 23:27:32 FINER [GenericExecutor@com.dynatrace.diagnostics.plugin.extendedexecutor.GenericExecutionPlugin.action] Entering getStackTraceAsString method
2018-06-01 23:27:32 SEVERE [GenericExecutor@com.dynatrace.diagnostics.plugin.extendedexecutor.GenericExecutionPlugin.action] setup method: password authentication: IOException, stacktrace is 'java.io.IOException exception occurred. Message = 'setup method: password authentication method not supported by server 'LXV5029''; Stacktrace is '''
I'm using exactly same configuration on my testing environment and run successfully. It just don't work on my production. I can use putty to ssh to that Linux server from my dynatrace server.
Is anyone has experience regard this issue? For example what else I need pay attention on Linux or Windows system level.
YC
0 REPLIES 0
