GenericOperation Plugin: issue with values retrieved
davide_mascolo
Contributor
Hi all,
I'm trying to use the 'GenericOperation Plugin' developed by @Jose C. but I'm facing issue when plugin retrieve the value from saved dashboard.
Our customer asked us to have the following metric:
Current CPU load / Concurrent Visits
But the plugin consider both measures with the same value ( 2nd metric selected)
So if I need to perform a division, I obtain always 1 as final result.
do you have any idea why this happens?
Thank you in advance,
Davide
davide_mascolo
Contributor
I think I found what is wrong with my plugin configuration:
If I choose my measures as "no split" the plugin is perfoming the division in th right way
Unfortunately I need to "split by Agent Name" because I need only my FrontEnd CPU's load and by "Application".
Selecting that options, the plugin retrieve 4 values instead of 2 (two for the first measure and two for the other one).
The measures used by plugin have the same value, so division result is always 1.
In attachment an extract from log.
I think that something needs to be done into the plugin, in order to manage different type of misures splitting. Any idea/suggestion?
regards,
Davide
davide_mascolo
Contributor
OK, problem solved. It was related to the order used to add the two measure to graph.
