Help in the second instance of collector
mecoronador
Participant
Hi all,
Your help raise a second instance of collector but send me errors in the log:
2018-08-15 17:03:20 SEVERE [MessageBroker] Failed to send CLUSTER_TIME message (target-type=SERVER, target-id=0), uri=null - CommunicationException: javax.net.ssl.SSLException: Unrecognized SSL message, plaintext connection?
2018-08-15 17:03:30 SEVERE [MessageBroker] Failed to send CLUSTER_TIME message (target-type=SERVER, target-id=0), uri=null - CommunicationException: javax.net.ssl.SSLException: Unrecognized SSL message, plaintext connection?
2018-08-15 17:03:40 SEVERE [MessageBroker] Failed to send CLUSTER_TIME message (target-type=SERVER, target-id=0), uri=null - CommunicationException: javax.net.ssl.SSLException: Unrecognized SSL message, plaintext connection?
2018-08-15 17:03:50 SEVERE [MessageBroker] Failed to send CLUSTER_TIME message (target-type=SERVER, target-id=0), uri=null - CommunicationException: javax.net.ssl.SSLException: Unrecognized SSL message, plaintext connection?
2018-08-15 17:04:00 SEVERE [MessageBroker] Failed to send CLUSTER_TIME message (target-type=SERVER, target-id=0), uri=null - CommunicationException: javax.net.ssl.SSLException: Unrecognized SSL message, plaintext connection?
2018-08-15 17:04:10 SEVERE [MessageBroker] Failed to send CLUSTER_TIME message (target-type=SERVER, target-id=0), uri=null - CommunicationException: javax.net.ssl.SSLException: Unrecognized SSL message, plaintext connection?
2018-08-15 17:04:20 SEVERE [MessageBroker] Failed to send CLUSTER_TIME message (target-type=SERVER, target-id=0), uri=null - CommunicationException: javax.net.ssl.SSLException: Unrecognized SSL message, plaintext connection?
2018-08-15 17:04:30 SEVERE [MessageBroker] Failed to send CLUSTER_TIME message (target-type=SERVER, target-id=0), uri=null - CommunicationException: javax.net.ssl.SSLException: Unrecognized SSL message, plaintext connection?
The second instance is connected
Any solution to this error?
Regards
In such situation you should go to server settings, Certificate managemenr and generate new certficate. After restarting collectors and server (it will be done automatically), everything should be fine.
