Hi,Difference between per violation & Instant in Incident Dashboard
ameya_deshpande
Participant
We would like to know the difference between per violation & instant in Incident Dashboard. It shows up under the Sensitivity column in the incident dashboard.
Kindly find the attached screenshot.
JamesKitson
Dynatrace Leader
Dynatrace Leader
In the past you may have been able to create "per violation" incidents but no longer as far as I know. For the ones you are seeing now that are per violation these are likely all built in incidents that will fire as soon as the event they watch for is detected. E.G:
  • Corrupted, Timed Out, or Truncated PurePaths
  • Performance Warehouse Imports
  • Stuck JVMs
  • Any custom events or deployments you create
  • Agent instrumentation being disabled
  • etc...
James
