Hi,need help in capturing a method after creating a sensor to that.
sangeetha_mitta
Organizer
we have created a sensor on one method but after creating sensor it should be visible in methods Dashlet. But we are unable to see that particular method which we have created sensor on that to capture.
please help us what could be the problem.@Sangeetha
harald_berger
Dynatrace Pro
Dynatrace Pro
Perform an Hot Sensor placement and have a look at the deployed sensors tab in the agent overview, to see if the new rule is active.
Also double check if the method is actually executed by taking a CPU sample.
Best
Harry
Thank you Harry.
