How can I create a method metric on Appmon?
I need to create a metric of programs that run on the mainframe and that appear in the purepath with the symbol "P" (generally the list of programs executed in the monitored environment can be visualized in dashlet "Methods").
BabarQayyum
Leader
Hello @HELOISA BUENO R.
Dynatrace offers following type of measures.
  • Agent based measures (such as host agent and monitor measures) provide insight into your environment and infrastructure. These measures give accurate environment data points related to hardware, operating systems, servers, and databases.
  • Transaction based measures give insight into your applications and transactions using PurePath information.
  • PurePath based measures are calculated from PurePath-extracted data such as Response Time, the number of SQL executions, or the number of exceptions. PurePath based measures can also be calculated from any visit data, including visit duration, visit counts, or conversion rates.
Right click on method and select Create measure the you will find the number of options to choose. At this stage you will have to decide what type of measure you required and what will be the purpose of that measure.
Have a glance on the blow link for more understanding about the server-side performance measure-specific attributes.
https://www.dynatrace.com/support/doc/appmon/admin...
Babar
