How do we monitor hadoop cluster with appmon7 ?
arunkumar_jola1
Newcomer
3 REPLIES 3
pahofmann
Leader
There is a FastPack for Hadoop, though it's a bit out of date, you can still take a look at the sensors provided there to get some insight into what is a good starting point for your monitoring.
If you have a test environment you can just go ahead and instrument it with java agents.
arunkumar_jola1
Newcomer
Thanks Patrick for your response. how do we instrument the haoop process? is it same as instrumenting the Apache Tomcat or weblogic.
Yes the instrumentation is done the same way.
