How does UEM Work
tarun_agastya2
Inactive
I would like to understand how does UEM work.Can someone help me
Default location will be for UEM->Default Application-> Agent location ->/
Is this location is a physical location or logical location and does dtagent-xxxx.js file physically exist?
If i want to change the Agent location can we pass any location or there must be specific location that needs to be passed and if it is physical file how can i download.
BabarQayyum
Leader
Hello Tarun,
I would suggest you to go through with the below link then let us know if you need more understanding. The documentation will give you a complete picture/information you are looking for.
https://www.dynatrace.com/support/doc/appmon/user-...
Babar
