How does host monitoring work ( on unix platform ) ?
adama_dagnogo
Contributor
In order to configure correctly our dynatrace agent (host
monitoring/linux), I need to know if the user starting the service need
to have a shell or if we can set the user with a no login option ?
Thank you very much
pahofmann
DynaMight Leader
DynaMight Leader
yes the user running the host agent on linux needs to have a shell set.
If you set it to /usr/sbin/nologin the host monitor process won't start.
Dynatrace Certified Master, AppMon Certified Master - Dynatrace Partner - 360Performance.net
adama_dagnogo
Contributor
Thanks 🙂
