How install AppMon agents on Window using shell scripting from Urban Code deploy
mao_phu
Newcomer
I currently have the following shell script to install AppMon 6.5 agents on Window Server 2008.
msiexec /i "F:\DynatraceInstall\dynatrace-agent-6.5.0.1289-x86.msi" APPDIR="F:\Dynatrace 6.5" /L*V "F:\DynatraceInstall\6.5Install.log" /qn /norestart
The scripts work, but the AppMon Agents Window service doesn't start when i run the script through Urban Code Deploy
1. Manually when log into server as Admin:
The script is good and install the agent in F:\Dynatrace 6.5 and Dynatrace 6.5 Window service start when i do it manually logged in as admin.
2. Ran through Urban Code Deploy
The script is good and install the agent in F:\Dynatrace 6.5, but the Dynatrace 6.5 Window service does not start when i run the same script from Urban Code Deploy.
I get the following message: "Window could not start the Dynatrace Web Server Agent 6.5 service on Local Computer. Error 1053: The service did not respond to the start or control request in a timely fashion"
Any one seen this before and know how to resolve it?
benjamin_johnso
Organizer
Hello, I don't suppose you overcame this issue?
jason_stearns
Newcomer
Did you ever find a solution to this issue?
