How to activate Hybris Dynatrace agent and connect to Dynatrace APPMON Server
sivashankara_pu
Organizer
florent_duchate
Dynatrace Pro
Dynatrace Pro
Hi
Hybris is typically deployed on an application server such as tomcat.
To install the agent please follow this documentation:
https://www.dynatrace.com/support/doc/appmon/insta...
As it will be a java agent, the generic installation steps can be found here:
If you are using Tomcat, there is more specific info here:
Regards
Flo
dave_mauney
Dynatrace Champion
Dynatrace Champion
After you get the agent connected, to get more Hybris-specific visibility, you should install the "Hybris FastPack": https://community.dynatrace.com/community/display/...
