How to add Cassandra DB for monitoring under Infrastructure Overview Tab in Dynatrace Appmon?
how could I add Cassandra DB for monitoring in Dynatrace Appmon? Cassandra DB is running as container under Docker. DTAagent is running on the host but still it is not visualized under Infrastructure Overview tab in Dynatrace Appmon.
Any hints?
6 REPLIES 6
BabarQayyum
Leader
Hello @Konstantin M.
Have a look in the below links for better understanding.
For instrumentation of the Cassandra client API, you have to inject the Java Agent, and the Cassandra Sensor must be placed in those Agent Groups that make calls to Cassandra.
https://www.dynatrace.com/support/doc/appmon/insta...
With the composition-based approach, you use the AppMon/agent Docker image that includes all variants of the AppMon agent that you can configure to attach to your existing Docker containers.
https://www.dynatrace.com/support/doc/appmon/appli...
Babar
Hello Babar,
thank you for the fast response and clear explanation.In case there is no Java agent running Cassandra DB could we somehow adopt the DB config to be monitored properly in Dynatrace?
Thank you,
Konstantin
The dynaTrace FastPack for the Apache Cassandra NoSQL Database enables easy out-of-the-box monitoring. The FastPack consists predefined JMX Measures for Cassandra, Sensors for Cassandra Server and Cassandra Clients, Business Transactions a Template Profile and Dashboards.
https://community.dynatrace.com/community/pages/viewpage.action?spaceKey=DL&title=Apache+Cassandra+Fastpack&_ga=2.30039036.259725321.1543125392-2117912594.1541409766
Babar
That's exactly what I was looking for. But my account doesn't have the right privileges to open the URL. Any suggestions?
Cheers,
Konstantin
Find the attached Apache Cassandra Monitoring FastPack
dynatrace-cassandra-fastpack.zip
Babar
Hello @Babar Q.,
thanks for sending the attached Pack, really appreciated it.
Cheers,
Konstantin
