How to add manually x-dynatrace headers into Load Runner REST API script?
nayeem_sm
Newcomer
nayeem_sm
Newcomer
Hello Folks,
Eventually, I had added the custom piece of code under global.h file and written the function in front of web_custom_request. However, for monitoring purposes we are using Dyna trace as web, but unfortunately we were unable to seeing the Tagged requests from Load Runner script.
Please find the custom code & function written in front of custom request for the same.
addDynaTraceHeader("NA=Transaction Name;PC= Transaction Name");
Custom code under global.h
void addDynaTraceHeader(char* header){
char* headerValue;
int headerValueLength;
int vuserid, scid;
char *groupid, *timestamp;
char* vuserstring=(char*) malloc(sizeof(char) * 10);
web_save_timestamp_param("TimeStamp", LAST);
timestamp=lr_eval_string("{TimeStamp}");
lr_whoami(&vuserid, &groupid, &scid);
itoa(vuserid,vuserstring,10);
headerValueLength = strlen(header) + 4 + strlen(vuserstring) + 4 + strlen(timestamp) + 1;
headerValue = (char*) malloc(sizeof(char) * headerValueLength);
strcpy(headerValue, header);
strcat(headerValue,";VU=");
strcat(headerValue,vuserstring);
strcat(headerValue,";ID=");
strcat(headerValue,timestamp);
web_add_header("X-dynaTrace", headerValue);
free(headerValue);
free(vuserstring);
Please do the needful help to us...!!!!!
