How to create UEM based BT split on Connection Type or Bandwidth ?
Hello, Is there a measure that captures Connection Type or Bandwidth as shown in attached snapshot for which splitting BTs can be created?
3 REPLIES 3
BabarQayyum
Leader
Hello Rajesh,
Use the bandwidth metric.
Babar
Hi @Babar Q.,
I am using appmon 7.0.10.1010 and nowehere I found the measure named "Bandwidth".
Pl see snapshot:
Update: So, as usual some "metrics" are not "measures" that is they are not created by default !
So, have to use the [+Create Measure] button.
Thanks It saved !!
Regards, Rajesh
Here is a great working snapshot 🙂
Saves a lot on drill downs!
