How to extract logs for specific agent group to track inbound and outbound communications
shikha_yadav
Guide
Need to track 3rd party communications to a specific agent group using AppMon 6.5
pahofmann
Leader
Is the information you want only contained in log files?
You could just create a Business Transaction for all calls to that agent group and split it by calling IP, or whatever is the relevant distinction you want.
Babar_Qayyum
Leader
Hello Shikha,
I don't think this will be possible to track the agent group or process level communication because in the AppMon we can have the agent host received/sent bytes per second informaiton.
Babar
