How to get the speed index in appmon 7.1
sai_tejaswi_gal
Newcomer
I've created Business Transaction and added the speed index in the calculate result part.But, i'm not able to see any value in the speed index column in the output.Can anyone help me on this?
BabarQayyum
Leader
Hello @Sai Tejaswi G.
Speed index is only available for load actions.
For AppMon Spring 2017 and later, the JavaScript agent captures both visually complete and speed index timings. Enable both visually complete and speed index capture for a System Profile by selecting the Visually Complete check box in the System Profile - User Experience settings.
Have a look on the below link for more insight.
https://www.dynatrace.com/support/doc/appmon/user-...
Babar
