How to setup dynatrace for basic instrumentation on Oracle EBS server (OAS/Forms server/ConcurrentProcessingServer)
pawan_sangal
Newcomer
I have used Dynatrace monitoring (i.e. basic instrumentation) on WAS (websphere application server) and capture the purepaths for a regular business flow/transaction. However I am new to setup the same on a Oracle application server (OAS). OAS being the middle tier in an Oracle EBS suite, it has Forms service/server, Web service/server and ConcurrentProcessing service/server. Also, the OAS communicates with DB tier (at backend) and with Desktop tier (at frontend). Please advise how I can setup or configure the Dynatrace (agent installation and agent mapping with dT client), assuming the OAS is on a windows platform.
florent_duchate
Dynatrace Pro
Dynatrace Pro
Hi
to instrument OAS 10 please follow the instructions found here:
https://community.dynatrace.com/community/display/...
If you are using 11g or 12c, the steps are different. The best approach is to modify the startup script to add optional jvm arguments to include our agent. See here for more details:
Please note that you won't capture anything interesting for the Forms side of OAS as it is written in native code so our agent don't have any visibility. Anything else using java should be fine.
Regards
Flo
