How to split aggregate data on web from BT measurements
jllompart
Newcomer
Hi everybody..
We have set one BT getting results from a Server-Side Purepath filter with 4 measures, all of them with the aggregation (Count) - Logic (or), so BT is providing any data following this logic.
Given that we have got 22 markets, spliting rules were calculated with a Parameter Value capturating all Values from a marketCode purepath service.
The aim of the survey is to study type of errors by market, but when BT is setted on Dynatrace web, we only get aggregated information of ALL exceptions counted on it.
So If you try to split this information by market, aplication only can give aggregated information by any market splited on it but not measurements dateilled data is splited.
Images has been attached fore more detailed information.
I nearly 100% sure we are setting BT wrongly and we need your help to get a best practice procedure as this BT rules is going to be a standard opereing procedure as we have 22 markets that must be followed.
Best regards for your help and attention...
3 REPLIES 3
Babar_Qayyum
DynaMight Leader
DynaMight Leader
Hello Julian,
Can you share the settings of splitting measure?
Babar
jllompart
Newcomer
Hello Baba Q.
Attached the requested info.
dave_mauney
Dynatrace Champion
Dynatrace Champion
Hi Julian,l
Copy your existing BT, and add each Filter Measure to the Calculate Results Measures list with an Aggregate of sum.
Then chart these Results Measures.
HTH,
dave
