How to stitch Purepath & Transaction Flow with no agent for one of the tier
sachins
Guide
We have got four layer architecture out of which we have installed dynatrace agents in 3 layers ( Internet Banking(IB), Middleware IIB MQ, Finacle core banking application server) . IB is a java based application and MQ(219) is based on IIB Message Broker, whereas the 3rd layer in the transaction is Gateway server, where only queues are installed so there is no agent in it. But the 4th layer is again Java based so agent is present. (Please find attached the architecture for better understanding)architecture.png
We want to stitch the transaction flow with all four layers, even though the gateway server doesn't have an agent. Let me know the feasibility & the way we could to do this.
Appreciate your reply & thanks in advance...
Sachin
BabarQayyum
Leader
Hello Sachin,
The Agent Development Kit (ADK) extends the capability of the AppMon APM solution to areas and scenarios that are not supported by default sensors. For example, you can use the ADK for a proprietary protocol or for instrumenting native applications. The ADK enables you to trace transactions across different platforms and technology types and to correlate the parts of the transaction from all tiers into one PurePath.
Review the below documentation for more understanding.
https://www.dynatrace.com/support/doc/appmon/integ...
Babar
sachins
Guide
Hi Babar,
Thanks for your quick reply. The missing agent tier has got only queues without MQ. I am not sure how can we use ADK for the same. Please explain it.
Thanks in advance.
Sachin
