I have recorded my application using ajax truclient protocol in loadrunner. The application is hosted in cloud . Can we monitor the cloud servers using dynatrace?
prathima_sundar
Newcomer
nishant_rama
Dynatrace Advisor
Dynatrace Advisor
Hi Prathima,
Is this application Java or .NET? whichever it is then recommended best practice is to have the collector as close as possible to the JVM's or application pools. e.g. having a collector in the cloud which then connects to your dynatrace server through a VPC. You will want to be careful here also as there are many considerations for monitoring applications in the cloud such as traffic, connection speeds, distance from collector, and other considerations. I would reach out to our services team to see if you can utilize flex points to have a dynatrace expert come onsite to architect a viable solution for you.
HTH
Nishant
