IBM MQ Queue Channel Monitoring Plugin issue
wkhurana
Newcomer
Hi Team,
I was
able to setup the monitoring for one of the MQ servers using IBM MQ Queue Channel monitoring plugin (9.1.25) initially it was
working fine, however after doing some setup changes i.e. only enabled the
Reset Command to execute, Unable to run the monitor getting “(KMQW000W)2042-Object_In_Use = 2042” Error.
Same stuff happened with different setup where I have changed the credentials.
wkhurana
Newcomer
@Asad A.'Ali, Asad' <Asad.Ali@dynatrace.com>, @Eugene T.eugene.turetsky@dynatrace.com
harshal_pujari
Dynatrace Pro
Dynatrace Pro
Hello Winkle,
Can you try the solution listed here so that multiple apps can access the queue?
http://www-01.ibm.com/support/docview.wss?uid=swg2...
Harshal.
