Incident alert not working how expected for Disk Storage Utilization
isaac_molina
Inactive
I have configured an alert for "Disk Storage Utilization" it work when the incident be upper to threshold establish. But the alert only works when the incident started and ended and the notifications not continuous executing if the disk storage still growing or continues with the same behavior.
JamesKitson
Dynatrace Leader
Dynatrace Leader
Actions on incidents (such as emails) can only be configured to occur at the start, end, or start and end of an incident. There is no way within AppMon to tell it to continuously send 'reminders' or alert again when a threshold violation increases further.
This post has some discussion on this as well as a link to an existing RFE/Idea in the comments: https://answers.dynatrace.com/spaces/148/uem-open-...
James
isaac_molina
Inactive
Hi James,
Thanks for you reply, I'll take a look at the link.
Isaac
