Incorrect DT counts for BT's compared to SQL logging counts
sponnada2
Organizer
HI All,
We have noticed the DT counts of GetAssessments,
GetAuthDetailsbyId, GetAuthDetails methods are less than our SQL logging count.we have placed sensors for these methods. What could be reason for this count mismatch?
Shyamala
3 REPLIES 3
kyle_kowalski
Dynatrace Pro
Dynatrace Pro
Are you calculating the number of DB statements in that DB? I believe the count you are looking at in the screenshot is the number of purepaths.
sponnada2
Organizer
HI Kyle,
Could you plesae help me out in where can i check the DB statements count?
If you drill into the Database dashlet for that BT that would be one way to verify but if you want to add the count long term you will have to add DB count as a measure under Calculate Results for that BT.
