Intermittent connection between agent and Collector?
christopher_teb
Organizer
I installed new Collector for more agents but its ever closes
connections to agents and reconnects them yet the bandwidth is good. It at times shows that are connected but later disconnects, why? Please help its very urgent and on PRODUCTION.
Br,
Chris
16 REPLIES 16
christopher_teb
Organizer
Any one there to help please?
Br,
Chris
Babar_Qayyum
DynaMight Leader
DynaMight Leader
Hello Chris,
Do you have any Firewall in between collector and agents?
How many agents are connected to your collector?
To keep start-up times low, it is necessary to deploy at least one Collector in every location/data center that is connected to an AppMon Server.
Check the following link for the collecter best practices:
https://community.dynatrace.com/community/display/...
Babar
Hi Babar,
Thanks for your support.
There is no firewall between the agents and the collector. They both located in the same data center and in the same LAN.
Br
Hello Chris,
Check the following two things, if you are sure about your network stability.
  • Open the agents overview and add the below two columns with the right click from the header and check the time.
  • Check the collector health fro the Start Center > Monitor > Dynatrace Collector Sizing (Buffer Saturation | CPU Usage | Memory Usage)
Babar
joshua_pavlica
Dynatrace Pro
Dynatrace Pro
For an urgent issue such as this, please follow the link below to create a Support Ticket with Dynatrace.
https://community.dynatrace.com/community/display/SUPPORT/How+to+get+Support
Thanks Joshua,
I logged a ticket(SUPDT-31869) but its not yet replied to
Br,
Chris
It looks like in the time I wrote the previous message someone commented on it. Please attach a Support Archive to that ticket following the instructions they gave. Keep us updated on what the solution is!
Kind regards,
Joshua P.
christopher_teb
Organizer
Hi Babar,
For a clear view of this problem, i have attached the Collector log
It mostly highlights this error,"
2017-03-21 09:47:10 WARNING [EventCollector] agent connection '_Concierge_Portal_72[MS7_UGPTTCOAPP09]@ugpttcoapp09:28866' reset due to an IO failure (prev event: 38, current event: 1): com.dynatrace.diagnostics.collector.agentcenter.EventCollector run:213
java.io.IOException: Stream closed.
collector00.zip
Br,
Chris
Hi Babar,
In addition, these two fields are empty.
Br,
Chris
Hello Chris,
The following message is in your logs.
The specified collector name dynaTrace Collector01 is already in use by another collector on host ugpdynatrace01. Please use a different collector name. This collector instance will be shut down.
Do you have collectors with the same name?
Babar
Hi Babar
Those fields are empty in the attachment.
"The specified collector name dynaTrace
down.
Yes that have been shown after shutting it down and restarting it again. It even surprised us why was showing that yet its killed. After a while we restart it and things get well but after 2-5 minutes, it gets disconnected again.
Br,
Chris
Hello Chris,
Below information is in also in your log that 'Agent closed connection during handshake'.
Which port you are using for collector and for the agents to connect to the collector.
03-21 10:17:03 INFO [AgentListener] Agent '10.156.201.71:27037' (version: 6.3.9.1009) closed connection during handshake.
2017-03-21 10:17:03 INFO [AgentListener] Agent '10.156.201.71:27038' (version: 6.3.9.1009) closed connection during handshake.
2017-03-21 10:17:03 INFO [AgentListener] Agent '10.156.201.76:39506' (version: 6.3.9.1009) closed connection during handshake.
2017-03-21 10:17:03 INFO [AgentListener] Agent '10.156.201.71:27035' (version: 6.3.9.1009) closed connection during handshake.
2017-03-21 10:17:03 INFO [AgentListener] Agent '10.156.201.72:35046' (version: 6.3.9.1009) closed connection during handshake.
2017-03-21 10:17:03 INFO [AgentListener] Agent '10.156.201.71:27039' (version: 6.3.9.1009) closed connection during handshake.
2017-03-21 10:17:03 INFO [AgentListener] Agent '10.156.201.72:35047' (version: 6.3.9.1009) closed connection during handshake.
2017-03-21 10:17:03 INFO [AgentListener] Agent '10.156.94.32:36768' (version: 6.3.0.1305) closed connection during handshake.
2017-03-21 10:17:03 INFO [AgentListener] Agent '10.156.201.81:35328' (version: 6.3.9.1009) closed connection during handshake.
2017-03-21 10:17:03 INFO [AgentListener] Agent '10.156.201.72:35048' (version: 6.3.9.1009) closed connection during handshake.
Babar
Thanks Barbar,
I used port 9998 for agents to connect to the collector.
Br,
Chris
sooryaprabha_mo
Inactive
Hi Chris,
As you mentioned whether you installed collector in new server or in the existing collector server(as a instance).
If its a same/different server, collector name should be different which we configure in Collector.config file.
Also if its in different server, in collector.config file "agent port =9998" you can use same in both servers.
But if its a same server(collector instance), in collector.config file "agent port = 9997" must change from 9998 port to any other port to avoid port conflict.
Also, in dtCollector.ini check the Memory allocated for collector, by default it is 2GB, based on the your total memory of the server(say 8GB), allocate 4 or 5GB to Collector.
Restart the collector services to check the connections.
Soorya Mohan
christopher_teb
Organizer
Thanks Mohan,
Attached is the file(dtCollector.ini), please direct me where i can make those configs.
Br,
Chris
sooryaprabha_mo
Inactive
Hi Chris,
As you highlighted inthe image,
Change from 2G to 4G in the below lines and restart collector service.
-Xmx4G
-Xms4G
Soorya Mohan
