Is it possble to filter purepaths by location(City) not Region?
christopher_teb
Organizer
I want to create BTs to filter transactions/purepaths by Locations(City). How can i do it because whenever i try to split the BT by locations i only get the Regions not the city and this happens when i select "Server-side-Purepath" in the BT. The Customer wants to know exactly where that purepath incident happened. Please experts help
Br,
Chris
8 REPLIES 8
Babar_Qayyum
Leader
Hello Chris,
Open the 'Country of Visits' measure and enable the 'Cities' for the required countries.
Babar
Thanks Barbar for your kind support,
Yes i tried to use that but it did not work. May be it works when you have selected either "User Action" or "Visits" but not "Server-side Purepath" because whenever i select
"Server-side Purepath", that Measure disappears as the snapshot below
Br,
Chris
Hello Chris,
We can have only 'Web Requests' Geo Information for the 'Server Side Performance'.
Babar
christopher_teb
Organizer
Thanks Barba,
Yes we have "web Requests" but i do not see that field for "Cities enabled for:" as below
This means for "web Requests" we cannot see the Cities?
Br,
Chris
Hello Chris,
Yes. It seems that Geo Information granularity is available only for the UEM.
Babar
christopher_teb
Organizer
Ok thanks Babar
Br,
Chris
Welcome Chris !!!
Joe_Hoffman
Dynatrace Champion
Dynatrace Champion
Chris, You're right, the cities data comes from the visit, so if you don't have visit data, (ie: no UEM), then that city data isn't available. But is it possible the city string is available on the serverside of your architecture somewhere? perhaps in a Session Variable, Request parameter, etc? If so, you could capture it and then split your BT on that value.
Good luck
joe
