Is it possible in Dynatrace Appmon to create a measure for CPU utilization for specific/selective Linux hosts?
lmalw
Contributor
Task is to create a incident for CPU utilization for selected Linux host servers in a system profile. Right now I am using the default measure "CPU Total Time (Host Performance)", which I will include/add inside incident.
Is there a way we can do the task for selective Linux hosts?
mat_cat_adn
Advisor
I see no way for Host. But you can do it on CPU Load of applications.
To do it, you need organize your Linux Host Server in specific Agent Group.
Then, Create a measure based a Current CPU Load on Server Side Performance > Agent Based Measures > Process Performance.
In detail tab, check calculate only for selected agents groups and select the Agent Group of your Linux Host Server.
And base your incident on this measure.
Mathieu
lmalw
Contributor
@Mathieu C
Thanks for the answer .....
