Is it possible to check how much memory DT agent is using?
mallempati_sree
Inactive
hi Team,
Is it possible to check how much memory Java Appmon agent is using?
Sree
5 REPLIES 5
christian_wegha
Advisor
yes that depends on the operation system. Which OS are you using?
Christian
HI Christian,
Its Red Hat Linux OS. Java Agent v7.0.32
christian_wegha
Advisor
Can you check the TOP command?
The top command is generally used to check memory and cpu usage per process. However it also reports total memory usage and can be used to monitor the total RAM usage. The header on output has the required information.
hi Christian,
Not on the Server box. We would like to check mem usage of DT agent in Appmon and to chart the details to compare if there is any spikes.
Babar_Qayyum
DynaMight Leader
DynaMight Leader
Hello @Sreedhar M.,
You can use the Agent Breakdown to know the time spent in the target application of the Agent which provides a view of accumulated performance data and secondly you can plot a chart for the Bytes Read from Agent measure from the dynaTrace Self-Monitoring which because this is often an indicator of the overhead caused by the agent.
Babar
