Is it possible to monitor Oracle databases via OEM (Oracle Enterprise Manager)
thorahelge
Participant
We are setting up Dynatrace for a customer with a large number (10s) of Oracle database instances.
The customer already has monitoring of these databases via Oracle Enterprise Manager (OEM).
In order to simplify configuration and maintenance, we are looking for a more efficient way to monitor these databases with Appmon.
Has anybody looked into creating a Dynatrace plugin for OEM that will fetch data on all the databases in one go? Is this possible and practical?
Ha anybody tried the same on other DBMSs?
mathieu_chatte1
Advisor
No, you have some explanations in this question :
https://answers.dynatrace.com/spaces/148/uem-open...
But, it have a Database Agent that could answer a part of your request :
Mathieu
