Is it possible to monitor the Pop-ups on a Page in Appmon?
mallempati_sree
Inactive
hi All,
We have a Product page where a Pop up displays when adding the product to Cart if in case the product is not available in stock. Is it possible to capture these Pop-calls to monitor how frequent these happens? Can someone let me know if anyone has implemented similar solution.
Sree
bobby_crumley
Dynatrace Mentor
Dynatrace Mentor
Hi Sreedhar -
You should be able to monitor anything that goes on within the webpage if you're using UEM. If that's turned on, you should be able to capture it and then make metrics on the results you get once you isolate the popup. I'd suggest making a measurement on the URI or method call that kicks off the "Not in Stock" pop-up. If you wish, check out the Web Dashboard's Waterfall, it's simpler to navigate and shows everything that happened and when.
