Is it possible to set thresholds for measures provided for Database Monitoring in dynaTrace 6.3?
chee_wang1
Newcomer
We would like to find out if it is possible to set custom threshold and configure incident reporting for new database monitoring feature provided in dynaTrace 6.3 such as create an incident and send a notification if active session count or ackground CPU usage beyond certain threshold set.
Chee
4 REPLIES 4
sonja_chevre
Dynatrace Pro
Dynatrace Pro
Hi Chee,
the part of the functionality enabling the database monitoring measures to be used for incidents isn't implemented in 6.3. However the scenario you are describing will work in the next release (scheduled for fall this year).
If you want to try it out before the official release, I would be happy to send you an invitation for our early access program - scheduled to take place during the summer.
Sonja
chee_wang1
Newcomer
Hi Sonja,
We are looking for database monitoring features below as well:
DB Process CPU
DB Process Memory Available
Cluster process monitoring
Reachability
Availability
Buffer Pool hit ratio
Tablespace/FS space
Auto-extents
Auto-memory
SQL - access/execution/explain plans
AWR/ADDM/ASH capabilities /stats
Optim reporting capabilities/stats
Service Log Monitoring
temp Filesystem space
Latch Waits
Deadlocks/Locks
Long-running SQLs
Avg SQL response time
Session cache utilization
Monitor
lag of standby databases
Monitor
GoldenGate availability and traffic flows
SQLServer:
Database Replica performance counters
SQLServer:
Availability Replica performance counters
Cluster
availability
Cluster heartbeat failures
Database Filesystem space
Database Status
Listener status
Synchronization health
Hung jobs
Agent job failures
Chee
Ashok_Swaminath
Contributor
are these alerts now possible with DT 6.5?
yes - this is available in 6.5.
