Is there a way to monitor an FTP session to see how long the connection has been open?
tdavison2
Organizer
Hello everyone,
I've been asked if there is anyway in AppMon (Plugin more than likely) to monitor FTP sessions to see how long the connections have been open?
Tom
3 REPLIES 3
tdavison2
Organizer
Actually, is there anyway AppMon, DCRUM, or a third party tool that could provide FTP Connections stats like # of Connections or Connection Time? I can't seem to find anything on how to achieve this.
Thanks for your help,
Tom
Hello Tom,
I did not get the exact information but just check the following links, if helpful for you.
https://www.dynatrace.com/blog/3-levels-of-network-monitoring-for-devops/
https://community.dynatrace.com/community/display/DL/FTP+File+Checker+Plugin?_ga=1.135866609.11618816.1488090824
Babar
Hi Tom,
I *believe* you can do this with DC-RUM since it's an option for you. If you can't figure out how to do it on your own I suggest re-posting this question in the DC-RUM forum here.
Hope this helps,
Dan
