Is there a way to set up a measure / incident for a specific server within a system profile?
Nestor_Navarro
Participant
I'm trying to set up a measure for System Monitoring > Host Performance > CPU Total Time, but I do not want the thresholds to apply to all of the hosts within the system profile. Is there any way to set up the thresholds for a specific server within the system profile independently?
shane_korbel
Dynatrace Pro
Dynatrace Pro
Nestor, you can set up a new measure for the server or group of servers you want by setting up filters for those specific hosts and then set up the thresholds for that specific measure.
dave_mauney
Dynatrace Champion
Dynatrace Champion
You can also set up alerts under infrastructure at the individual host level or at a group level. This is the preferred way to deal with infrastructure alerts in the later versions of the product, I think.
Here is the documentation:
https://www.dynatrace.com/support/doc/appmon/administration/server-administration/infrastructure/ale...
