Is there an integration of Dynatraace Appmon with Unit Test Framework built in c#
I have found the link https://community.dynatrace.com/community/display/DL/Test+Automation+Plugin+for+Jenkins?_ga=1.680151...
This talks about dynatrace integration with Java(Unit Test Framework) I believe.
Please help me understand if the same is also supported for c# / .NET unit Test frameworks.
5 REPLIES 5
Babar_Qayyum
Leader
Hello Anantha,
Check the following link for unit/integration and performance tests for:
  • Java Test Framework
  • .NET Test Framework
  • PHPUnit Test Framework
https://community.dynatrace.com/community/pages/vi...
Babar
Hello Babar,
Thank you for the information. This is useful while this just helps capture performance results from unit/integration test but the plugin does this - "Retrieve Dynatrace Test Results and push to Jenkins"
I am more keen to understand if this is possible using the same plugin. Reason-I only see Java results integration with Jenkins. If yes, is there any documentation ?
Apologies if I didn't mention it properly.
Hello Anantha,
For the .net agent, the test run id must be passed through the environment variable DT_TESTRUN_ID
Please check the following documentation:
https://github.com/Dynatrace/Dynatrace-Jenkins-Plugin/blob/master/README.md#nant1
https://community.dynatrace.com/community/display/DOCDT63/.NET+Agent+Configuration
Babar
Correction- please read above line as -This talks about pushing performance data of unit/integration test framework of java to Jenkins. Please help me understand if the same is also supported for c# / .NET frameworks.
Hi Babar,
Thank you very much.
I have to try configuring.
Anantha
