Is there an option to generate appmon web purepath dashboard in client
ravi_kumar11
Mentor
Is there a way to generate a AppMon purepath webdashboard in the client so that I can see the purepaths which are very slow, slow, Normal and fast.
Ravi Kumar
Radu
Dynatrace Pro
Dynatrace Pro
Hi Ravi,
So what you're saying is you'd like a way to be able to quickly filter the PurePaths Dashboard inside the Desktop Client the same way you do for the web client?
The only advice I can give is to create some Business Transactions (e.g. Fast PPs, Slow PPs, Very Slow PPs), where you filter by "PurePath Response Time" set to different thresholds which indicate the levels of slowness. Then you can use these BTs inside the PurePaths dashboard as a quick way of filtering them out.
Hope this helps.
Best regards,
Radu
I will try this Radu..
