Is there any way to hide JVM arguments for Java Agents for a specific user group?
sukanta_ghosh
Newcomer
I am using AppMon 7.0. We have Java agents for MuleSoft. We want to hide the JVM argument from the users (or completely hide the "Agent Overview" dashboard). But we need to keep the "Infrastructure" dashboard visible to the users. Please let me know if more information needed to visualize this use case.
Babar_Qayyum
Leader
Hello Sukanta,
You can use the permissions mapping to control the visibility to the end users.
Review the below link for more understanding.
https://www.dynatrace.com/support/doc/appmon/admin...
Babar
sukanta_ghosh
Newcomer
Thank you Babar for the quick answer. I have already checked the permission management document. There is a option to allow or disallow access to "Status Overview" dashlet through "Analyze System". But this will prevent the users to see anything under "Status Overview" (Infrastructure as well as Agents Overview dashboard). I am looking for a solution which will only prevent users to see Agent overview (or moreover the JVM argument of a Java agent) but the user will be able to see the Infrastructure dashlet for overall resource usage for individual servers.
