Issue with incident rule when URL monitor and DB monitor are combined
s_nolfi
Participant
we are having some problem with an incident that is not working well, our incident is composed by measures from URL monitors and DB monitor in logic and/or, follows a screenshot:
Except for DB connection all measures come from URL monitors.
We have another incident that monitors just DB
Now, we have saw that when DB connection is violated, "Rete Applicativa -Database" does not trigger:
The strange thing is that if we remove the measure "DB Connection" from conditions of "Rete Applicativa -Database" the incident works good. Does somebody have any idea about this behavior and how to fix it?
Thanks in advance
Simone
joao_vilacia2
Inactive
Hi, @Simone N.
It would be interesting to check the thresholds set for the two metrics to identify why the incident is not being triggered.
In other words, check the conditions that are being used because one of the conditions is not being evaluated correctly.
s_nolfi
Participant
Hi @João Luiz Vilacia B.
these are the thresholds (equals for all the incidents):
- SocketTimedOut: Lower Severe 0.01 (in order to filter SocketException)
- HostReachable: Lower Severe 0.99
- HttpStatusCode: Upper Severe 302
- DB Connection: Lower Severe 0.99
Timeframe: 5 minutes
Because "Database" triggered threshold was violated but i don't understand why "Rete Interna - Database" did not. Continuing with the analysis, without modifying anything, we have saw that when measures related to URL monitors were violated, in some cases incidents triggered, in other cases no without an apparent reasons for these different behaviors.
Suggestions?
Thanks in advance
Simone
