Issues placing Hot Sensor
katarzyna_kepk1
Newcomer
I'm using AppMon 6.5 and I have issues placing HotSensor for several nodes in the cluster (all nodes have the same configuration).
This is the ERROR I get:
Hot Sensor Placement result for Agent 'XXXXX': finished with errors
java.util.concurrent.ThreadPoolExecutor: JVMTI_ERROR_UNSUPPORTED_REDEFINITION_SCHEMA_CHANGED]
Agent Details:
Sensor Implementation:
Can you please help?
3 REPLIES 3
harald_berger
Dynatrace Pro
Dynatrace Pro
This is a known issue with u144 and has been fixed with 6.5.30.
Best
Harry
ahanchat
Guide
I am getting above error on DT Server 7.0.0.2469
Anirudha
vmotupalli
Newcomer
Any update on this thread. I am facing Similar issue
