Issues with Hot Sensor Placement
leo_selochnik1
Participant
HotSensorPlacementIssue.docx
We are experiencing issues with Hot Sensor Placement DT 6.1 & Java 8u25 (see attached screenshot).
Any ideas?
Leo
jacob_payne
Inactive
Others with the same issue as you have solved the problem by restarting the JVM that is throwing the error (see this support case). Also, for more details about the particular errors you were experiencing, see this Community post. Perhaps someone recently enabled a sensor pack that doesn't support Hot Sensor Placement?
