JBoss webapplication pure path is not showing on dynaTrace client dashboard
sujit_singh
Newcomer
I have configured JBoss web server agent after the start of JBoss dynatrace is showing agent is connectect but its not shwoing any data on dashboard. UEM Sensor is enabled but no data. In agent status dashboard its showung even count, class loaded count but transaction flow status and pure path is blank.
Please provide me steps to fix this issue.
Sujit Singh
3 REPLIES 3
BabarQayyum
Leader
Hello Sujit,
Check your Sensors Configuration and make sure that the following sensors are active and start PurePaths:
  • Java Web Requests
  • Java Web Services
Babar
Hi Babar,
Both sensors are already enabled.
Sujit
Hello Sujit,
Share the following information:
  • Which JBoss version do you have?
  • Which OS?
  • Is this running in the standalone mode or domain mode?
Also share the screenshot of agent (highlight or provide the name) where we can see the event count, PurePaths etc...
Babar
