Maximum size for a collector
ksk_natsume
Inactive
I want to know about how many trunsaction (how many agent) can be get by one collector.
in sizing tool, if the "collector weight" increase, the number of collector is increase as well.
■what is "collector weight" ?
■if the machene of memory-heapsize will increace, Can I add agent unlimitedly? or not?
3 REPLIES 3
Babar_Qayyum
DynaMight Leader
DynaMight Leader
The heap recommendations for the Collector (1 GB for a maximum of 100 Agents, 4 GB for a maximum of 200 Agents and 8 GB for a maximum of 400 Agents) in the deployment scenarios described here are based on the following assumptions:
  • Application Size: 25,000 loaded classes
  • Instrumentation Depth: 10,000 instrumented
  • Clustering: High Number of "similar" applications connected to a Collector.
For further information please check the below link:
https://community.dynatrace.com/community/pages/vi...
Babar
ksk_natsume
Inactive
Babar
Thank you for your answer!
I understand that the heap size of memory is effecting number of agents,
but how about the amount of trunsactions?
trunsactions are not relate to collector sizing??
Best regards
Ryotaro
Yes. The number of transactions also impact the collector sizing. You can find the recommendations of collector sizing from the below link in the case of transactions limit per day.
https://community.dynatrace.com/community/display/...
Babar
