Measure Availability Monitor Plugin is not working after upgrade to v6.5
mallempati_sree
Inactive
After upgrading to v6.5 from v6.1 the Measure Availability Monitor plugin is not working.
Am seeing the below logs in collector
2017-02-22 21:54:26 SEVERE [MeasureAvailabilityExecutor@Real User - OrderConfirmation] getFileFromUrl method:FAILED : Retrieved dashboard report is not a XML type
2017-02-22 21:54:26 SEVERE [MeasureAvailabilityExecutor@Real User - OrderConfirmation] execute method: getFileFromUrl method:FAILED : Retrieved dashboard report is not a XML type
Can someone help us in identifying whats the issue?
Sri
andreas_grabner
Dynatrace Guru
Dynatrace Guru
The reason could be an authentication problem. I think I discussed the same problem on the Monitor Plugin Community PAge with a user: https://community.dynatrace.com/community/pages/vi...
See the last comments on the bottom of the page where we discuss about HTTP/HTTPS and authentication
Thanks Andreas
