Monitor Database Instance with ssl required
michael_stoetti
Newcomer
I want to monitor a SQL Server 2012 Instance using dyntrace personal edition (6.5), unfortunately our servers require connections using ssl.
How can I configure dynatrace to use property "ssl=require" within the connection string?
3 REPLIES 3
Radu
Dynatrace Pro
Dynatrace Pro
Hi Michael,
What is your full connection string?
Since the fields in the DB Agent setup are essentially just building the connection string...
.... try editing the fields so that in the end, the connection string is as you need it.
I am not 100% sure this will work, but it's worth giving it a quick try.
Radu
Actually, the proper way of manipulating the connection string is in the Debug mode in client. When you're in the Debug mode, the "JDBC connection string" is editable.
You can enter the Debug mode by pressing Ctrl+Shift+F9 in the AppMon Client.
Thanks, Wiktor!
It did feel a bit odd doing it through the fields.
