Monitor configuration for 'APMaaS Script Metrics'
rajanikanthanka
Inactive
For plugin 'APMaaS Script Metrics' what configuration is needed to run Monitor?
What credentials should be given here(username and password)?
How to know which Host to be selected too?
https://community.dynatrace.com/community/display/...
Rajani
5 REPLIES 5
pahofmann
Champion
There is a built in Dynatrace Synthetic (APMaaS) integration in appmon now, you can read more about it here: https://www.dynatrace.com/support/doc/appmon/integ...
Hi Patrick,
I have gone through the link. What I can understand is I can chart synthetic tests to view availability, response times, and failure rate data.
But can I also chart it based on Script Names. How do I do that?
Rajani
Hi Rajani,
Can you please elaborate on what are you trying to accomplish? When you configure the APMaaS monitor, you are already specifying a script name, so when you chart availability, it is for that script/test.
On the same chart, you can add other availability metrics for other scripts. That should give you availability of all scripts/test in a single chart.
Does this help?
Hi Harshal,
Thanks for making me understand.
So just by enabling Synthetic Monitoring from Dynatrace client we cannot chart metrics without a Monitor running right?
If we are running a Monitor what should be a Host? Is it can be a Collector?
Rajani
Yes you get test names with the OOTB APMaaS integration. You can chart response time etc. based on the Test Name, you also have a Synthetic Test Tile in the Web UI which will show you the availibillity of the different Tests.
