Monitor of Docker Components in Appmon 6.5
subbarayuduk
Participant
Hi Team,
How to monitor below Docker components
  1. Host CPU – above 80%
  2. Host Memory – Above 80% and 90% on red
  3. Host Disk Space - Above 80% and 90% on red
  4. Container CPU - Above 80% and 90% on red
  5. Container Memory - Above 80% and 90% on red
  6. Container Swap - Above 40% and 90% on red
  7. Container IO
Subbu
BabarQayyum
Leader
Hello Subbu,
Use the following docker container plugin to retrieves CPU, memory and network stats from Docker containers via the Docker Remote API.
https://community.dynatrace.com/community/display/...
Babar
subbarayuduk
Participant
Thanks Babar!!
I used the documentation but unable to configure, Is there any specific config file need to instrument.
Subbu
