Monitoring Talend - is it possible ?
adama_dagnogo
Contributor
My team would like to monitor Talend ( https://www.talend.com/ ) .
Is it possible to catpure "Talend events" with Appmon?
Thanks.
Adama
12 REPLIES 12
pahofmann
Champion
Do you have any information on the technologies used for Talend and the "Talend events"?
adama_dagnogo
Contributor
It's based on Java
Joe_Hoffman
Dynatrace Champion
Dynatrace Champion
Adama, AppMon can monitor (almost) any java process. Some are easier than others.
For example, if the Talend Events are implemented with Servlet handlers, then it should all be automatic and just work. But if they are implemented with POJOs, then custom entry points will likely be required. Defining a custom entry point for a 3rd party app can sometimes be an adventure, the CPU sampler can be a big help.
It's certainly worth exploring. Good luck.
joe
david_n
Inactive
Hello Adama,
At my client they began exploring monitoring Talend jobs with AppMon and ran into the issue where the Talend jobs would spin up a JVM then once the task was done the JVM would disappear. This made it very hard to instrument the jobs and place the necessary sensors. If your configuration is the same, what you might want to try is creating a parent JVM and instrumenting that with the agent. Once that is setup, run your jobs and place the necessary sensors to capture the information that you need. Our project got haulted so we never got to test this approach so I would be interested to confirm that it works.
Hope that helps,
David Nicholls
adama_dagnogo
Contributor
Hello Joseph and David,
Thanks for your answers.
I will post the result of our project. The agents will be installed tomorrow morning. 🙂
Adams
fporroalonso
Inactive
Hi @Adama D. Did it works? Were you able to monitor Talend apps?
adama_dagnogo
Contributor
Hi @francisco ,
Monday or Tuesday, I will give you a feedback about it.
Thanks.
Adama
fporroalonso
Inactive
Talend use Apache Karaf, which is not a supported
technology. Check from the forums:
https://answers.dynatrace.com/spaces/148/uem-open-q-a_2/questions/160024/monitoring-apache-karaf.html
adama_dagnogo
Contributor
Some updates :
-installation of the agent
-configuration of the agent
-In the Talend administration portal, we just have to put the Dynatrace configuration string in the Java Job parameter. ( one job , one agent )
-CPU sampling
-Create sensors & entry points
We have some results and it seems to work fine.
Thx.
Adams
Hi Adama, can you please help with more details on how to achieve this
Hi @Adama D., thank you for contribution.
Can you provide more information? I'm trying to monitor Talend with Dynatrace.
Thanks a lot!
fporroalonso
Inactive
Ok, this means 1 agent/license per job.
Thank you!
