My Sensor Pack for Slf4j is not working
heinz_grob1
Inactive
Hi
We are using Slf4j as logging framework in most of our applications. Unfortunally its not a part of Dynatrace Java Logging Sensor Pack.
I tried several ways to get Slf4j logging entries displayed in logging dashlet, but without success. The only way how it works was to create a method sensor in a system profile, but this does show the logging entries only inside a purepath, but not on the logging dashlet.
Steps that I did so far:
a) Added class org.slf4j.impl.Slf4jLogger with method <all methods>(*) to Java Logging Sensor Pack, Place = include, Capture = active
b) Created a new sensor pack with class org.slf4j.impl.Slf4jLogger with method <all methods>(*) to Java Logging Sensor Pack, Place = include, Capture = active
c) Created a Method Sensor Rule in a system profile with class org.slf4j.impl.Slf4jLogger with method <all methods>(*) to Java Logging Sensor Pack, Place = include, Capture = active
c) shows only entries in purepaths, a) and b) does not work, means I did not see any Slf4j entry in a purepath nor in the logging dashlet
Do you have any idea why Sensor Pack Updates/Create is not working in my environment?
As Info: We are using Dynatrace 6.5
Thanks & Regards
Heinz
harald_berger
Dynatrace Pro
Dynatrace Pro
Hi Heinz,
Please note that delivered sensor packs like logging sensor always need agent side specific code. So by simply adding additional rules will not make the agent smarter, and the instrumented methods will not appear in the logging dashlet. Feel free to post an RFE.
best
Harry
heinz_grob
Inactive
Hi Harry
Thanks for this info.
Regards
Heinz
