Need help splitting Web Request by its method name
thanes_bala
Participant
I'm trying to split filtered WebRequest by it's HTTP method name {POST, GET, HEAD}
I have list of specific URI that needs to be split by {POST, GET}
I was able to filter by the defined URI but couldn't split by the method name.
any help will be highly appreciated.
thanks,
Thanes
9 REPLIES 9
Babar_Qayyum
Leader
Hello Thanes,
Did you try the 'Web Requests - Method' as splitting in the BT for the filtered Web Requests?
e.g. below screenshot is the result for the /orange.jsf URI filter where splittings are in the form of POST and GET.
Babar
thanes_bala
Participant
Thanks Babar.
Using by Method worked well. Now I'm trying to add more Web Requests filtered by URI;
while using filters with Logic or/and, I cannot get the additional web requests that can be represented in the same report. Only the first one"UserSession" works the Image PDF, CustomerAccounts don't retrieve any data.
Can you please help?
here's my filter page screen shot:
Hello Thanes,
Make sure you assigned an upper sever value in all of the filtered web requests. Secondly add the application in the Splittings if you want the baseline in the future for this BT.
Babar
thanes_bala
Participant
Hi Babar,
I do have the upper severe value set. Still the second filter entry with "or" logic doesn't get filtered for any data. But the same as separate BT works.
Any ideas why?
Here's the screenshot with upper severe value set:
Here's the screenshot where the filtered web request pulls data in separate BT;
Thanes
Hello Thanes,
Open the Business Transaction and extend the Filter column to check whether all the web requests are gathering there.
Babar
thanes_bala
Participant
Not all are getting gathered there, only the user session web requests: please see the screen shot sorted by the filter column;
Thanes
Hello Thanes,
Just drag the column on the right side or double click on the column line to extend because I can see avg... in the screenshot which means some data is there.
Babar
thanes_bala
Participant
you're right ,it does pick up but aggregate the data together, see below;
anyways to separate each entries such as;
User Session - POST
User Session - GET
Accounts - POST
Accounts - GET
Thanes
Hello Thanes,
I guess for this you will have to create three different business transactions.
Babar
